A needle is a needle is a needle?
Re: A needle is a needle is a needle?
You can try fixing the needle yourself. I've touched up the tips of needles by dragging them carefully over a sandpaper sheet. If you drag the tip backwards while rotating, you may be able to straighten it out.
scorpiomikey
Post by scorpiomikey »
LyleW wrote:Contact USA airbrush or Badger and ask them if another badger needle will work.
If my experience with corporations is anything to go by they will say no. Even if the answer is yes. Because they want you to buy a particular product due to profit margins or some garbage.
I can try.
jkim wrote:You can try fixing the needle yourself. I've touched up the tips of needles by dragging them carefully over a sandpaper sheet. If you drag the tip backwards while rotating, you may be able to straighten it out.
Ive done this before to polish the needle in my Iwata Neo. I might give that a go. If it breaks it breaks. I need a new one anyway and if it works then it staves off having to buy new ones for a little bit and i can deal with the postage times.
if Don Wheeler is still around (airbrush expert) he may know. Search online for him.
scorpiomikey
10 days to respond.
Hello,
Sorry, only that needle will work. Where are you located?
Candy
So i guess im importing.
