I just received the Aires resin cockpit set for the Ki-84. It took awhile to ship from Europe but even with shipping costs, it was the cheapest option. With the aftermarket goodies already included in the kit, I now have FOUR versions of the seat: the kit, Eduard photoetch, Mastercasters resin and Aires resin.
I took some time to inspect the Aires set. It has some very fine casting with many of the levers and switches molded into place. Which means, shipped overseas, there might be some breakage. Which there was. I noticed a few levers and knobs broken off, which should be easy to replace. There was also a wiring run that was broken. Wiring on Aires resin can be hair-thin so I debated if I should just shave the wiring off completely. Instead, I decided to attempt a fix it with fine copper wire, which seemed to match the thickness pretty well... maybe that's what they use on the masters.
I was pretty happy to have pulled off such a delicate repair. Can you see it?
Will have to wait until the primer or paint is on the part to really see if I was successful. I will pack this away for now since this build is not going to start for some time.
