Zvezda 1/48 Bf109F-4 - DONE! (again) New Pics
wing_nut
Senior Member
Re: Zvezda 1/48 Bf109F-4
Post by wing_nut »
Many thanks Manny for confirming my suspension. The idea of stencils 1st then WW should have been a forgone conclusion since I went it did out down the camo 1st. That would've of course had all he stenciling there already.
wing_nut
Senior Member
Post by wing_nut »
Jimmy, didn't mean to bypass you. But I have been thinking the same thing you mentioned about this build. I went into this with the idea that it was nothing more than a filer while I waited for the part for the Corsair. WHICH ARRIVED YESTERDAY...WOOHOO. This is a great kit and it deserves more than a passing interest. i am at least hoping that it gets it all out of my system before I get back to the Corsair.
The stupid part of this is there was a crap load I could have been doing on the Corsair while the part was on it's way. I think that had to do with that I didn't really know if I was even going to be able to get the part when I started the 109.
wing_nut
Senior Member
Re: Zvezda 1/48 Bf109F-4 - DONE!
Post by wing_nut »
It's as done as I am getting it. I'll likely retake the final photos since white on a white background wasn't as easy as I thought it would be. i had to play with the pictures and they are just OK. I'll try a different camera too.
aah, my favorite one!
Great work, well done Wingnut!
And nothing to complain regarding the pictures
Tamiya F-4B Phantom II 1/48
Kinetic F-16A (new tool) 1/48
Manny1943
Post by Manny1943 »
This is a REALLY nice build...my only critique is that I'm.o the spinner and props are too green...I find that the props look best in a lightened black and the spinner should be a black-green, which is black w a hint if green...
wing_nut
Senior Member
Post by wing_nut »
Thanks Kari
Manny, I cannot disagree with you.. I mixed up some black green The weathering process really brought the green to the surface. It';s not as bright as in the photos but as i said, your right, it's still too green. Last Night I had the idea of making a black filter with very thin Vallejo and build up transparent layers over the green.Worked pretty ell I think. I'll get some new pics later. Appreciate the honest feedback.
wing_nut
Senior Member
Re: Zvezda 1/48 Bf109F-4 - DONE! (again) New Pics
Post by wing_nut »
OK, really domne this time.... I think...
Fixed the green, added some exhaust staining and wetahered the exhust pie since they were too shiny.
Ha, just wanted to write something about the exhausts today at noon but I thought "let him post the new pics first".
And here you are with a flawless looking wintercamo one-o-nine. I really like this one!
Manny1943
Post by Manny1943 »
wing_nut wrote:OK, really domne this time.... I think...
Okay, that's more like it. It now passes Manny Inspection...
