Monogram 1969 Z to SS Camaro-MOVED TO COMPLETED-07/20
- midnightprowler
- Addicted Member
Re: Monogram 1969 Z to SS Camaro-"Sneak Peek" 06/22
Is the body shell itself a little warped Joe? That engine is stellar!
1 Corinthians 15:51-54
1 Thessalonians 4:13-18
Ask me about Speedway Decals.
Thanks Lee. Yeah it's got a little twinge to it up front. I think I can knock it back out without harming the paint finish though.
That's a stunner Joe - love the engine!
Thanks Stuart!
Well folks I've got the engine compartment finished. There are some things that are wrong and more things I could've added to the actual bay itself but hey, ya gotta know when to say "when" at some point. I chose to do a simple "fill in" at the passenger side rear of the engine bay where Monogram placed the battery initially and install it in the correct location. You'll see that the two rectangular holes for the hood hinges have been filled in and the molded in crappy wire details were removed from the firewall, the original master cylinder was overhauled and detailed along with the added brake lines and a windshield washer bottle was added (along with the battery) from the newer Revell Camaro release. Radiator hoses were constructed out of 16 gauge electrical wire and a dullcoat applied over both. Hose clamps were made from spare PE frets. All of the molded in detail on both fender wells was removed which instantly improved the engine bay appearance to me.
Re: Monogram 1969 Z to SS Camaro-Eng Compartment Completed-0
Man that looks good. If this shot was posed on that garage floor base that you're making instead of the cutting mat, you would be hard pressed to tell that it was not the real deal.
I second what Carlos said; this is some amazing modeling. Have you started that engine yet to make sure it runs right?
Thank you both very kindly.
I finished up with the chassis as of this morning. The base chassis is all original down to paint and detailing through much younger eyes. I did do some repair painting here and there and applied a light wash on the fuel tank to bring out some of the detail.The front suspension, rear differential and leaf springs are all replacement parts and I had to make a custom driveshaft using the end pieces and some aluminum tubing. The mufflers are from the newer Revell Camaro release and the lead and tailpipes are silver solder. And with that.............we're off to emblems and bumpers and a few touch up items here and there.
Re: Monogram 1969 Z to SS Camaro-Chassis Completed-07/14
Oh man that looks really good!
Now you need to display that on a mirror base to show off all that work...
Thanks Carlos. That's a great idea.....
