Fujimi 1/72nd Ju 87D-3
Posted: Mon Jan 31, 2022 9:10 am
And my second build, 72nd Stuka no 8. My 4th Fujimi build and second of their D's. Made a start on the Stuka last weekend, this is the kit, i am doing the subject on the box art, S7+AA.
The instructions say it a D-1, but the photo's clearly show the thicker armoured pilots windscreen of a D-3.
I'm useing an Eduard PE set along with a few other AM parts. The Aires resin pit designed for the Academy kit will fit in this, as i found out when i built a D-5, but as i had the Eduard set anyway, figured i would use it. The PE set is missing some detail thats in the resin one, but i'll use some parts from the spares box to fill it out.
I got the PE parts fitted painted and dry brushed. Also drilled out the hole and fitted a quickboost resin compass.
I also got the wings together, cut out the molded landing light and fitted the guns. There are 2 options for the wing guns in the kit. One with exposed barrel tips for the D-1 and another with extended fairing and covered opening for the D-3. But photo's show that both variants could have either. I am guessing the covered fairings are to stop dirt getting in to the barrels on take off, and the covers do seem to be fited more often to aircraft in dusty enviroments, such as the desert. The photo's of the aircraft i am doing are not that clear, but it does look more like the covered option so thats what i fitted.
Got most of the major parts fitted to the Stuka including fitting a quickboost compass and getting the wings on once the fuselage was together. No major fit issues as i expected.
Then got the canopy on and all the sub assemblies ready. As you can see i am leaving the undercarrage off. I've also learnt my lesson when it comes to adding actuators and balances to soon, have had to scratch more of those than i care to remember, so i am painting them seperatly.
It got a primer coat followed by the undersides being painted, so will be able to mask off in a day or so.
And i saw on Scalemates that Special Hobby are re-boxing the lovely Academy G-2 into 2 seperate issues, a D-5 and a D-5N/D-8. Thats great news, hopfully they will do the same with the G-1 to produce a new D-1/D-3.
Now, if someone would just produce a C.
