1/48 Italeri Cessna 172 complete
Re: 1/48 Italeri Cessna 172
Fermis wrote:Slung some paint last night.
The white one...pretty straight forward!
Went with the Croatian Air Force on the other. I pretty much did guess work for the colors...mixed up the green using OD, Russian Topside grn, Chromate Yellow, and light grey. Mixed Red and Brown for the mottling....all freehand.
Very nice - I really like that camo on the Croatian Air Force bird - it really suits it. If I had a real 172 I'd be tempted to paint it up like that (any idea what the black panel under the wing is for?)
Most interesting look on that Cessna now... :hmm:
Fermis
Post by Fermis »
portman wrote:
...any idea what the black panel under the wing is for?
I know it looks black in the pic...it's actually green, and only slightly darker than the green on the rest of the plane. I'm guessing it's to cover up whomevers markings were there before they acquired it....maybe just covering up the civil reg. #s...???
Paul
Post by Paul »
Man, you flew the wheels off of those things.
Fermis
Post by Fermis »
Glad we are back!!!
In the down time, these builds have been completed!
Overall, not a bad kit, and does well OOB.
The only issues I encountered(kit wise)...very tail heavy, nothing some lead can't take care of. A little bit of trimming is required at the front/center of the wing part, where the windscreen meets up with the roof. The nose gear is a bit too straight up/down, it should angle forward a bit. I just bent the gear a little.
The only things I did different/added were to replace the exhaust pipe with aluminum tube, I snipped off the beacon and strobe from the tail and replaced them with clear sprue, and added clear sprue for the nav light (painted with Tamiya clear red/green) and added the antennas on the tail (stretched sprue).
Re: 1/48 Italeri Cessna 172 complete
Great couple!
Outstanding work, Fermis. Thank you!
Fermis
Post by Fermis »
Thanks guys!
LyleW wrote:Outstanding work, Fermis. Thank you!
Thanks for passing the kit along. Half the fun was learning a little bit of the history of the Mithias Rust "incident". Interesting...and BALLSY!!!
I took the build with me to the airport, the other day. The snowy background was too much, and the plane just became a silhouette in the pics...no good. The model sits in the display case at the airport now.....awaiting the opportunity for some decent picks with the airport backdrop...Texgunner style!
:shoutout: Nice pair of private parts... I mean private planes :giggles:
The red square landig has it historical significance. But that Croatian scheme is just so cool.
Return to “Member Reviews”
