Tamiya 1/35 M21 Mortar Carrier
CallSignOWL
Re: Tamiya 1/35 M21 Mortar Carrier
Post by CallSignOWL »
so, do you paint it all together like that?
lawman56
Post by lawman56 »
For the most part. When I build something simple, I will. Otherwise I paint major assemblies first, then details. My Sd.Kfz. 250 is being painted in stages, but only because of the complicated construction. All the tools, weapons, etc... are being painted separately. These US half tracks are basically a box, much like a tank, so I find it easier to shoot the whole thing in a base color, then pick the details out.
Joe
Illegitimi Non Carborundum
lawman56
Post by lawman56 »
I'm in the detail and crew phase now.
Trying out some peeps.
Joe
ahhh, the Mortar Maggots are finally showing up to get to work supporting the REAL Infantry... the riflemen :tease: :stirpot:
lawman56
Post by lawman56 »
Stikpusher wrote:ahhh, the Mortar Maggots are finally showing up to get to work supporting the REAL Infantry... the riflemen :tease: :stirpot:
They probably got held up arguing over who had the better K ration.... :winkgrin:
Joe
After having a nice cup of hot Joe warmed up in a fire of cheese charges under a steel pot...
lawman56
Post by lawman56 »
:rofl:
Joe
Stikpusher wrote:After having a nice cup of hot Joe warmed up in a fire of cheese charges under a steel pot...
lawman56
Post by lawman56 »
As the build draws to a close, (I'll post pics of the vehicle at a later date), I decided it would be driving through a damaged town on it's way to the front. Being the detail oriented nut job that I can be, I decided that resin cobblestone didn't look good enough, so I created my own using spackling compound. I used a piece of cardboard taped to one side to give me height, tape around the edges to keep things tidy, and then put it on.
Here you can see where I've measured and scribed horizontal lines approx 1mm apart, then started scribing stones with a sewing pin held by a pin vise.
Here's after I finished scribing. Now on to painting!
Joe
Joe, this is pure art! Looks easy to do but surely needs a lot of artistic talent to get such a fantastic example of a stone base! Image
Are you doing resin copies of this?
