Good to know! Thank you, Duke!Duke Maddog wrote:...
Thomas, I've never seen any difference between the shine before and after Alclad Aqua Gloss whenever I've used it.
1/48 Academy Mig-21PF N. Vietnam
- Thomas_M
- Admin
Re: 1/48 Academy Mig-21PF N. Vietnam
- jelliott523
- Advanced Member
I will echo what Duke stated, it did not change the shine at all, if anything it may have actually made it look better, some areas looked a little dull before the Aqua Gloss. The coat is very smooth and the decals should "crossing my fingers" go down nicely. I have read several posts around the modeling forums that stated that applying a gloss coat will cause changes to the metallic finishes, I'm thinking that it must occur with their application techniques, because I've sprayed clears (Aqua Gloss, Model Master and even Future) over Alclad, AK Xtreme and even Ammo of Mig's acrylic metal colors with no change to the sheen.
jelliott523 wrote:I've got her ready to start adding the decals. I applied a gloss coat of Alclad Aqua Gloss over the top of the Xtreme Metal. Then I'll do some minor repair work to the canopy seam to fix the boneheaded mistake. All-in-all, I think she is going to look OK, probably be a 5-footer, but this is my first true NMF project, and I've learned a ton from this one.
I love this build Jelliott! Looking sooo good!
- jelliott523
- Advanced Member
I'm calling this one done. This was my first all NMF aircraft and I've realized I still have a few tricks to learn, but I'm enjoying the education!
Reason: Corrected picture links - Thomas_M
That looks excellent! You have done far better on the multi-shaded metal parts than I can do. I still can't get that right. Congrats on a well-made plane.
That is quite nice! ...in a well-used way.
- Thomas_M
- Admin
Those different shaded panels give this one so much life and make it interesting to look at!
