Putty it away! Or not?
Re: Putty it away! Or not?
These days I use CA for 85% of my gap filling needs. The rest I do with styrene shims or Squadron White Putty.
From large gaps to small: milliput, Tamiya putty, mr Surfacer 500, tip exx correction fluid.
Furthermore, I like to limit problems with fit by using shims, spacers and ofcourse test fitting and sanding.
- Tojo72
- Master Member
I really like Mr Surfacer 500,just apply it to the seam with a toothpick,when it dries,I just smooth it out with a Q-tip and alchohol
- Thomas_M
- Admin
But sometimes even on small gaps it need to be applied twice because of shrinkage when drying. Twice the time.Tojo72 wrote:I really like Mr Surfacer 500,just apply it to the seam with a toothpick,when it dries,I just smooth it out with a Q-tip and alchohol
Ah yes, good old Mr. Surfacer. Had a few "shots" with it on several projects now, and it turned out really good.
