1/48 AMT P-40F
Re: 1/48 AMT P-40F
Damn, I missed the finished build. Looks great Stik!! :shoutout: :shoutout:
Re: 1/48 AMT P-40F
Medicman71 wrote:Damn, I missed the finished build. Looks great Stik!! :shoutout: :shoutout:
LOL! No worries! :wink: Better late than never. Thanks for looking in and commenting Doc. Sometimes it can be hard to keep pace with everything going on in here.
Re: 1/48 AMT P-40F
Especially with my work schedule. :giggles:
Re: 1/48 AMT P-40F
You did a fantastic job on this aircraft, Carlos.
Re: 1/48 AMT P-40F
Thanks Kenny. I am quite happy with the end results in this one.
Re: 1/48 AMT P-40F
Ok, the post script on this build... I added the antenna wire made from E Z line, and whipped up a simple base....
Thanks for looking... again...
Re: 1/48 AMT P-40F
Nice! I never seen the antennas go from wingtips to tail when most WW2 era usually are from canopy to tail. Well done, Carlos!! :shoutout: :shoutout: :shoutout:
Re: 1/48 AMT P-40F
Thanks Tom. Yes, the single wire configuration is more commonly seen on most fighters. P-40s used both types of set ups. If you build a P-40, check photo references to see what type was used on the one you’re building.
On the commo side, each of those antenna configurations gives a different signal “footprint” so to speak.
Re: 1/48 AMT P-40F
very good looking model, like the color, have build a similar one with these unusual antenna, :P1:
Re: 1/48 AMT P-40F
Thank you CL. Desert camouflaged aircraft have very attractive color schemes.
What aircraft did you build with the V antenna? I know that some RAF types had IFF antenna wires that went from the fuselage to the horizontal stabilizers in a similar configuration.
