1/48 Academy F-5E Lightning
Re: 1/48 Academy F-5E Lightning
Medicman71 wrote:Very nice! The cockpit looks great! I didn't know that this version of the P-38 was called the F-5E.
Yes, the F-4 and F-5 WWII USAAF photo recon aircraft were based off of the P-38. The difference being the base model. Any suffix to the F-5 nomenclature differentiate further Lightning sub variants.
Here is a list and article on all USAAF WWII F types.
https://www.defensemedianetwork.com/sto ... -fighters/
Interesting. Learn something everyday.
:that:
Make that :P1: times three.... Interesting indeed.
silentbob33
Senior Member
Post by silentbob33 »
When I bought the kit, I didn't realize it was the photo recon version, so when I got home and saw "F-5E" on the box I did some digging and learned about all that.
Here's a pic of the inside of the nose with my makeshift cameras inside (they're just some leftover bits from some Warhammer 40K kits).
I put some fishing sinkers and some bb's in the ends of the nacelles to keep it from tail sitting and closed her up.
On the Bench: 1/48 Encore A-37B Dragonfly
That’s coming along real nice!
Put weights into the front end of the spinners as well. I did that on my P-38 build. The nosewheel too if need be. The center of gravity on a P-38 Model is way aft, so to balance it out, you have to weight down every forward area possible. I don’t know how I’ll do that on a Droop Snoot P-38.... :hmm:
P-38 Lightning kits are one of the few that are notorious tail sitters. I remember having done one in my youth years. Weights in the nose is not always enough as I’ve learned the hard way myself.
Nice work!
silentbob33
Senior Member
I finally have paint on. The bottom had some kind of strange wrinkling on it, I'm not really sure what was going on there but I've fixed it the best I could. At least it's on the bottom where not too many people will be looking at it. I primed with flat black, then sprayed Testor's silver out of a rattlecan. After that dried I picked out a few panels with a couple shades of silver and aluminum. Since this plane was in the South Pacific at the end of WWII, I'm chipping a bit more paint than I usually do since those birds really took a beating from the elements.
I also got the props done as well. There's still a little bit of touching up to do here and there.
