Show us your work area!!!
-Latest Acquisitions
Fermis
Re: Show us your work area!!!
Post by Fermis »
Adam wrote:
Fermis wrote:
I've been there!!!
It is mystically magical...and stuff!!!
It was probably the rum! Actually not even probably.. it was the rum! Remember when I passed out in my chair and then you forgot your pants?? ;)
LET'S......GET....AWKWARRRRD!!!!
Remember when you brought my pants back to my house????!!!!!!!!!!!!!!!!!!!!!!!!!!!
Fermis wrote:...Remember when you brought my pants back to my house????!!!!!!!!!!!!!!!!!!!!!!!!!!!
:shock: Now I get curious: did he have his pants on when ringing at your door? :?
Adam
Post by Adam »
I had my pants on I think... not Jeremy's.
This could explain the blond wig.
lawman56
Post by lawman56 »
Ok, you asked for it!
As you can see, my space is a little limited right now, due to construction. That bench used to be clean. Then I had this brilliant idea to remodel my garage :shock: . Anyhow, my bench is an old computer desk, tucked into the corner of my 26ft x 14ft garage. The remodel is probably 75-80% done. Just a little more drywall work, a little more electrical and I can start putting my shelves up for my smaller models. My plan is to have a 10 x 14 area at the end my bench is at, and the rest will be an around the wall, open (basically a square, open in the middle), 16 x 14 HO model railroad layout. Under the side facing my work area, I plan to build enclosed, cabinet type display cases. One for my HK B-17G and the other for my B-25H. Both will have clear plexiglass fronts, and lighting. Between that and the train, you can see why I've run an electrical outlet every 6 feet! And also why I'm trying to whittle my WIP's down some.
If you close at the left side of my bench, you can see my Priest on a stack of junk, my Albatros looking very much like many pics from WWI, behind it, the tail of the 1/144 B-1. On the right, various body parts to create a crew, and the B-1's cockpit in my soldering stand as I paint the nose art by hand, under that magnifier.
Joe
Illegitimi Non Carborundum
Now I'm envious. Nice workspace, Some people get all the high-tech toys!
well, you said your paint booth was high-tech! I have a room in the basement...not the whole basement. Yet.
