Mil Mi-4 Hound HobbyBoss 1/72
BsYamato
Re: Mil Mi-4 Hound HobbyBoss 1/72
Post by BsYamato »
I'm really slow in these days and also few time to post updates that i've alredy pictured :( work and hot summer are proud enemies for hobby :lol: :lol:
Looking good BSY - it looks like a cracking kit.
BsYamato
Post by BsYamato »
Thanx Portman :)
Back on the hound too, two session of works:
The Ip need some surgery, cut in the middle and used unused instruments to build the side consolles as the real one
Removed original rudder , scrathed new ones and moved backward
Rea doors, oob except for little steps , one par side
modified original seats, the co-pilot in turned position to allow passage unde the cargo zone
test fitting
Added cargo floor parts, as i modified the first bulkhead in shape and position these parts are needed. The hole in the center allow the access to the gun nose position
More details added to the front bulkhead
first aid boxes added
To allow good covering of bottom cockpit putty session glued all other control levers, also added details on the back of IP
The detailing session is almost finished, few things to add before painting session :)
At the next!
:yikes: :bow:
I am with Lyle , this is some impressive work.
BsYamato
Post by BsYamato »
Thank you friends :)
Last night few works i did, just added wires on the IP back and started to details the side acces door but no pictures, i hope start to paint it this afternoon
BsYamato
Post by BsYamato »
Updates on the Mil :
Wires on the back of IP, starting to detail the doors, after i totally removed the upper layer till the window and scratched the structure with plastic sheet
Cockpit and IP with black and the wires organized
Grey on, two two layers plus primer
fuselages , same story
and other pieces
and tail halves and front naca for gunner with a sort of bed added
added a little stick on the central consolle
The cieiling with a little touch of color
Bulkhead with some detail painted and IP drybrushed in white
The front of bulkhead , an under cover of engine bay i added
more painted colors
cockpit and front gun
wheels in black
a testfitting :)
that's all for tonight :)
At the next
Manny1943
Post by Manny1943 »
Impressive work on this MOFO...
Paul
Post by Paul »
I wish I had the gumption to do all that tiny wiring as you do. It looks outstanding.
BsYamato
Post by BsYamato »
Thanks for comments :bye:
Time to close the wip , actually few adjusts left to do , sorry for the delay :bow:
Interior painting finished, washing and drybrush done:
gun upper IP and engine bulkhead ready
cargo bay ceiling
IP ready, a touch of clear glossy on the instruments to simulate glass
Fuselages ready
Front gun glued to the nacelle
Cockpit and ceiling and floor glued on fuselage
engine bulkhead too
Glued fuselages withouth problems and.. withouth weight on the nose ...
after i remeved the nose to put these walls to prevent to see trought the air intake on the nose, another time i forget the weight..
first layer of thinned 89 with a touch of white for bottom color
two views from the back
green on! i used pure 30 from humbrol
the lines bugs between the two colors i resolved after with tthe blade edge passing on the line and a toothpick with thinner
added grips on the fuselage
Starting to perform postshading, on the 89 used the medium grey 144
a large white stripe on the cargo doors was done , instructions means about silver but pictures tells another story :)
Stripes on tail rotor done with paint, decals provided by the kit but not same finish as regular paint
Postshading and highlights on the green. Used the 116 for darker areas and the 30 lighted with yellow and white for highlights. Same story, whit drybrush tecnique
Finally i put the gears legs so i rember .. the weight on the nose!!! :scream:
In the picture i already resolved the problem putting lead pieced throught the hole between the nose and the gun post hole
almost all the pieces drying
glossy coat before decals, as my usual used regular 35 gloss coat, two thinned layers
Decals on, the only problem on one of points of the bottom red star :(
For the cutted side stars alignment i put the larger part on the cargo doors , the fixed it to the fuselage with tape and put the smaller part on the fuselage correct position
Washing panel lines after another glossy coat to seal and protect decals, then final coat of semigloss clear paint.
Glued the wheels too :)
dirt on the main rotor
and shaft
last images of the wip, last pieces glued and some view. As i finish to write here will make last works to finish the hound , thanks for view and comments the wip :Beer:
Just as final notes, i added four little rods on the cargo door hinges to help positioning them in the correct way.
As i was happy with this build rapidly started the smaller helo from hobby boss i had in the stash, the Mi-2 , fuselage closed in about three days!! soon will post he too :D at the next!
