Italeri B-26K, or A-26A tbpc
April 1, 2021 through 12/31/2021 - Anything from the Vietnam Era, aircraft, helos, trucks, boats, tanks, artillery, figures, dioramas....if it walks, crawls, rolls, rattles, flies, hovers or goes "boom", it is in. Any scale.
Re: Italeri B-26K, or A-26A tbpc
I can see all images. :lashed:
I can see all the images, and what a fantastic looking model this is going to be! I should get me one as I only have the WWII version built. I will only build mine OOB though; I can't afford to get all these extras....
Norman
Senior Member
Post by Norman »
Looks really good.
I kinda backed up and restarted on this one, as I found that the interior should be black, which I hate. I got a CMK interior set and removed the Italeri parts which are not correct for a Viet Nam era Invader, it includes the On Mark dual controls and full width instrument panel. I lightly oversprayed the green interior with flat black, next I will do a clear coat and do some highlighting. The CMK set seems to fit pretty well, although the fit of the resin panel part needed some work.
A little more work on the A-26, a gloss coat followed by some wear and highlights from using a Prismacolor silver pencil. Some Aizu .7 mm tape was painted dark earth and stuck to the seats, then a flat coat was applied over everything but the PE instrument panel. Yeah, I know, it's black. I hate black interiors. Getting in an airplane with a black interior is a little too much like crawling in a cheap casket, in my opinion.
Looks good John. Glad to see this one back on the bench.
Agreed, good to see this one going again!
keavdog wrote:Looks good John. Glad to see this one back on the bench.
:P1:
I like it John! Excellent realism here!
No pictures, but I put filler in about 8 areas on this one today. None of the inserts fit very well, there are two where the remote turrets were on earlier versions, and the nose didn't quite fit either.
Return to “Vietnam Era Group Build 2021”
