AFV Club 1/35th M109A2 Op Granby
Bish
Re: AFV Club 1/35th M109A2 Op Granby
Post by Bish »
I now have the hull finished to the paint stage. I have not used all of the PE for it as some is for inside hatches i have closed and other parts are IMHO best left off as the kit parts are more realistic. I am not a big fan of voyager sets and now i only buy them where i just want a somthing to add and no one else does anything for that kit and the spares box doesn't have it (mainly anything that isn't German). So this is the hull now.
And have now started on the turret. Same again here for the PE, picking carefully what parts i use and which i don't. The barrel is from the kit.
Work on the turret continues.
Looks good Bish. I overlooked earlier that you picked up a PE set super detail this project. I’m looking forward to the next update on this one.
Bish
Post by Bish »
Thanks Carlos. I got the PE mainly for the tools clamps, track guards and trhings like that. I'm checking pics carefully to see if i ned to replace parts and also to confirm the british vehicles carried those. I need to change a few things such as the antena bases and jerrycans bt most of it seems as the US vehicle.
Bish wrote:Thanks Duke. What kit is that one.
Mine is the Riich Models kit, same as my -A6. I will be looking for another -A2 to make British.
Nice job on that hull, and the turret is coming along well. Looking great!
Bish
Post by Bish »
I had not realised Riich did armour in that scale.
Thanks, its coming along now.
Yes, they have the M1091A2 the M109-A6 and the ammunition carrier that goes with them. So far that's all the 1/72 scale kits they have. They are very well detailed too.
Bish
Post by Bish »
Ye, saw those kits when i looked them up. Hopefully they will do more subjects in that scale.
Amen to that! I certainly hope so too!
Bish
Post by Bish »
Bit of a long update. I got the turrety finished a couple of weks ago. Plenty of PE here. But i again i didn't use everything. The PE set included hinges and the locking mechanisim for the ammo locker door, but i felt the kit parts were much better. After i took the pics, i realised i had put the 4 rear bins on wrong, so they were then removed and fitted the right way.
I took a Clansman antenna mount from the spares box, this is a resin Accurate Armour piece that came with my Warrior conversion set.
Then i was ready for primer and paint. Nice easy scheme, over all desert sand, i used the Xtracolor gulf War sand, although this colour has been is use for British desert vehicles for a long time.
Followed by the decals. The decal instructions don't have an image of the rear for this vehicle, so i added the rear chevron based on the others on the sheet.
I also got the Fruil tracks together. I found these a real pain, every link had to be drilled out both front and rear. They also have different links for where the track goes round the drive sprocket and rear idler so it not just a case of sticking them all together.
After a couple of coats of Aqua gloss, tine for some weathering. I gave it a light dry brush, a panel line wash, light dot filtering and finally some steaking useing AK's DAK streaking grime.
Next up, i will be painting and adding tools and various stowage before some final dust effects.
Looks great Bish. Lots of fiddley bits for sure!
