They are on backing paper just like decals. But to attach them to the model CA needs to be usedCeaser_Sa1ad wrote:First off: Thanks all for the info, I have decided against the AM cockpit. Seems like too much fuss, and if what is said is true, it may be unnecessary. The Yahu dash looks good, but I am so super confused at Quinta Studios. How on earth do they 3d print decals??? How does one use them?
Revell P-51 Mustang Aftermarket parts
- tempestjohnny
Re: Revell P-51 Mustang Aftermarket parts
Therrrrre it is!! CA glue!! And now I know as well. lol
Well, it turns out the the 1/48 Revell P-51D does have a PE set out there. Although it is probably long OOP, as it’s one of their early sets.
https://www.scalemates.com/kits/eduard- ... g--1087852
Don’t worry about the Monogram label. The kit was originally molded and released by Monogram, pre merger, back in the day.
- Ceaser_Sa1ad
- Master Member
I understand what you mean about the inability to see the work/parts replacing what is normally there. Quickboost looks like it has some good options, and the ultracast is also promising.Stuart wrote:In modelling, like anything else, you tend to learn by doing - I still say if you want to have a go with resin then give it a go, but maybe start with something less arduous than a full resin cockpit on your first go - leave that for your second build!![]()
In my humble opinion (and bare in mind I hate working with PE and Resin), I've never much seen the point of fitting a full resin cockpit to something like a 1/48 WWII fighter anyway, because even with the canopy open chances are you won't see most of it (1/32's a different story however). If you want to lift a cockpit, to my mind you want to concentrate on the visible aspects, so a good IP, seatbelts and a decent paint finish will work wonders.
If you wanted to dip your toe in the resin pool, Ultracast (in Canada) do a really nice P-51D seat with moulded belts. I suspect it's for the Tamiya kit but I'm sure you could make it fit. The Yuhu IP would be good as well, although there are others.
https://www.ultracast.ca/product-p/ult48016.htm
Other than that, I'd look at some drop-in (ish) replacements as you see fit - exhausts, wheels, gun barrels can all be changed - there're company's like Eduard, Quickboost that can supply those. You might also want to wire the radio tray behind the pilots seat if you want to add a bit more detail.
As I said before, post the build up here - it's be great to see how you get on!
Cheers!
However I think in the end I will just go with quinta decals. It seems like the most detail per price.
- Ceaser_Sa1ad
- Master Member
I understand the monogram label. I couldn't find a set at a good price though, and I have never worked with Photo Etch anyway. Thanks thoughStikpusher wrote:Well, it turns out the the 1/48 Revell P-51D does have a PE set out there. Although it is probably long OOP, as it’s one of their early sets.
- Ceaser_Sa1ad
- Master Member
Good to know, thank youtempestjohnny wrote:They are on backing paper just like decals. But to attach them to the model CA needs to be usedCeaser_Sa1ad wrote:First off: Thanks all for the info, I have decided against the AM cockpit. Seems like too much fuss, and if what is said is true, it may be unnecessary. The Yahu dash looks good, but I am so super confused at Quinta Studios. How on earth do they 3d print decals??? How does one use them?
I agree. Why go through the trouble of constantly test fitting a new resin cockpit when you can invest in a nice Yahu instrument panel, 3d panel decals, AM seatbelts, tires, gun barrels, etc...
I hate working with PE myself and will avoid them unless the kit is lacking details.
If you really have your heart set on a resin cockpit, save it for a second P-51 kit. Tamiya kit practically put itself together. I did a Revell 1/32 P-51B Mustang kit and it fought me from start to finish. Don't get me started on the 4 or 5 piece clear canopy assembly on that kit. Hated every minute of it trying to get it to fit seamlessly.
- Ceaser_Sa1ad
- Master Member
I am really looking forward to doing a tamiya kit now, after all the good sounds.
As for the multi part canopy....
- Gary Brantley
Actually Johnny, Quinta suggests CVA glue, as well. I thinned some Evergreen Canopy Cement and used that to attach the IP on my Bf-109E-7. I imagine some good old Elmers would work as well.tempestjohnny wrote: They are on backing paper just like decals. But to attach them to the model CA needs to be used
Heh... so you know all about the multi-part canopy then.
