Tamiya Flat Base?
Proud Marine Dad
Re: Tamiya Flat Base?
Post by Proud Marine Dad »
Gary Brantley wrote: ↑Mon Jul 15, 2024 7:36 am
Stikpusher wrote: ↑Sun Jul 14, 2024 9:03 pm
Yes it is! I love the stuff!
On its way! 👍 :grin:
At that price? :shocked:
Nope, I found some closer to home! :grin:
Proud Marine Dad
Awesome.
Proud Marine Dad
BlackSheep214 wrote: ↑Mon Jul 15, 2024 12:21 pm
Proud Marine Dad wrote: ↑Mon Jul 15, 2024 12:07 am I want to give Alclad a try.
Just don't get their gloss black base coat. There's been horror stories about them.
Thanks for the heads up.
Gary Brantley wrote: ↑Mon Jul 15, 2024 11:19 am Carlos, please indulge me for one more question; what thinner (if needed?) do you use with this Humbrol clear? :hmm:
Nowadays I prefer to use lacquer thinner with the Humbrol Flat Coat. Before that Testors Universal Enamel Thinner was my go to, but since that has been discontinued… :bored:
Play with your ratios on a test mule subject for best results.
Stikpusher wrote: ↑Mon Jul 15, 2024 7:14 pm
Copy that! Thanks! 🥃
Carlos, I've been doing some 'net research and find numerous complaints about the Humbrol matte varnish; it seems many felt it turned chalky white on their model. Have you ever experienced that? I will sure test it on my paint mule first, but I want to prevent any issues before they happen, I guess. :grin:
I suppose if it’s not thinned at all or barely thinned it could do that. But no, I haven’t had any of my models turn chalky white from the stuff. If you put on a heavy coat it will give a typical overdone Matt coat look, but nothing out of line. All I can say is to thin it down. A little goes a long way. And unlike many other flat coats I’ve used, this stuff won’t give that satin look. I’ve had that from Tamiya & Gunze in the past.
Good to hear that, Carlos! 👍 The Hobbycraft 109-7 was the last model I clear-coated with good ol' Model Master acrylic flat and it looked very "satiny". I found out that the needle on my Gaahleri AB was too small and spraying the clear flat through it made it look that way. :headslap: I switched over to the old Paasche H and tried it again; voila, there was the flat look I wanted. Maybe not as matte as I wanted though for a bird based in the North African desert. :wink:
Carlos, before I sprayed Future for a glosscoat, this was the effect I had:
After the gloss was sprayed, so much of the faded look was obscured. I was disappointed and hoped that a good matte coat would bring it back. It did help, but it still looks shinier than I want. I'm hoping to try that Humbrol over it next, but I will definitely try it on the paint mule first.
Here, you can see what I mean; not as much contrast left between those carefully "faded" colors:
My usual go-to clears, both flat and gloss is Testors in the big bottles - both enamel based. I also have flat and semi-gloss acrylic clears in Pollyscale. (or is it Aeromaster? I can't recall :bag: )
