No worries. I have a tendency to be the "jet guy" on forums.Floki wrote:Wish I could help but I know nothing about the kit or most jet aircraft to begin with.
1/48 Academy F-4J Phantom
Re: 1/48 Academy F-4J Phantom
Yes I have but thanks for the reply.speedgraflex wrote:Brent, the only alignment tip I found so far was from Greg Wise, and I am certain you have seen this:
The main landing gear and gear bays were built up next, this consisted of framing up the sidewall structure boxes and adding the gear legs. I used the bottom wing as a jig to ensure the correct angle position. As a personal building practice, I did not add the gear legs at this point. Happy so far I glued the main gear bay framework into place and added the speed brake wells. Before closing up the wing assembly several holes need to be opened in the bottom wing halve and a few more in the top wing halves. Next up was the burner cans and intakes.
I wish I could be more useful. My buddy gave me a jet fighter model as a Christmas present so I am kinda on the hook to build a jet this year. I really am gonna read through your builds again before I start! Cheers, bud.
Got the landing gear legs and wings sorted out.
Perfect Medic!
Landing gear looks straight! But I worry about them being attached so early in the game. Are they secure enough to avoid being snapped or pushed out of alignment due to future steps?
Yeah... something I always worry about is those early gear attachment, with no option for later.
Yeah I'm worried too. But unfortunately there's not way around it. I'll just have to be more aware of them and try not to break them off.jkim wrote:Landing gear looks straight! But I worry about them being attached so early in the game. Are they secure enough to avoid being snapped or pushed out of alignment due to future steps?
Well this has ground to a halt. Remember that the front fuselage wouldn't close cause of the Eduard cockpit? I used the Dremell to sand the bottom of the cockpit to paper thin (even going through in one spot).
IT STILL DOESN'T FIT!!!!
