Revell Spitfire Mk IX 1/32
Re: Revell Spitfire Mk IX 1/32
Similar to stretched sprue, you can also use strips of plastic card. I like to do this, if I want to finish the piece separately before gluing into place.
Another option using the stretched sprue approach is to put the sprue after the two pieces have been joined and weld it into place using Tamiya Extra Thin cement.
Wow... you redefined my definition of how a filled seam should look right there. Beautiful work, John.
:P1:
John, that fixed seam has now a synonym; "Pure"
Nothing more, nothing less..
:shoutout:
Excellent styrene shim work on the 262 gun bay covers! :shoutout:
Thank you sirs! Sometimes good modeling work is the stuff you don't see. Like the removal of the gun blisters on the same 262...
Hey John, don't fool us. You just had two versions of that kit at hand, didn't you? :tease:
Dang it! There's no fooling you guys! :tongue: You can barely make out the outline of the removed bump in that first pic.
I just checked out that big beautiful build thread over on the LSP forum, John. Some excellent additional angles:
Thanks you guys for discussing this. This sub-topic is helping me learn quite a lot, and I know this’ll help me in the future. Much appreciated!
Just peeking around here... part of me thinks, just glue those wings and fill those gaps! I miss reading about this project.
