Medic's Texas Viper
Re: Medic's Texas Viper
Finally got the nose stiffener plates attached. These were not nearly as easy to install as the others.
:shoutout:
You nailed er you glued that just right! Brilliant!
Thanks Bruce! They were not easy.
Got the exhaust painted.
Purty! Lookin’ good.
Thanks Bruce!
Cracking build Mike!
Thanks Stuart!
Sorry for the long time between updates. I've been trying to make progress with the F-4 and the F-102. Been working on the canopies for the Viper. Need to work more on getting the main one clearer after getting rid of the seam down the middle. I test fitted the canopy and the instrument cowling kept getting in the way. More work to figure out why. Think I got it now.
I always follow because there is a lot to learn and your work is really inspiring. It is tough balancing several builds at once. Canopy looks good! Are you trying to fit areas front to back or side to side?
Return to “Jet GB by Portman”
