1/72 Hasegawa P-3C Orion
Re: 1/72 Hasegawa P-3C Orion
Looking good Mike. I'm interested in doing one of these down the road.
Thanks guys!
I added metal tubing for the exhausts because the kit ones were broken already. I also added the MAD Boom.
That looks sharp MIke. I need to expand my brass inventory.
I seem to be using it a lot for engine exhausts. The Prowler has then too.
So I'm building the Quickboost props and it has a jig do set the blades. It also has a hole in the bottom to drill a hole so you can attach them to the engines. But what I don't know how to do it drill that hole. Do I glue the hub to the jig? I have no idea.
I would guess you drill the hole through the into the hub (assuming there's a hole in the jig) then put rod/sprue etc through the jig and into the hub in order to rotate the hub prop by prop. Just guessing
I've got one prop done, three to go.
looks superb Mike!
That plane has some pretty lines. It really looks the part!
