Revell 1/32 F-4G Review & Build- update 12/13 (pg.19)
Look here at SPAModeler kit previews and reviews!
Re: Revell 1/32 F-4G Review & Build- update 10/27
And I also began work on the gizmology for the rear IP forward side.
And I created the APR-38 mid band receiver for the bottom of the nose fairing...
More in a few days...
Re: Revell 1/32 F-4G Review & Build- update 10/28
I am just giddy. This is coming along very goodly.
Thanks Lyle... but I could really use a good photo or three of the bottom side of the nose fairing and the antennas there. Nearly every other area of the F-4G airframe is covered on one walk around or another. But there... :Beaver:
BTW, those last photos were done with my new phone. Taken, edited, uploaded, and posted. All I can say is that it takes real good close in shots... :hmm:
More progress today... :yahoo: First thing I did was add some strip styrene for shims on the step where the lower front meets the right side
while the glue for that was drying I took a trip to the LHS for supplies. Mostly paints, but I knew that I could be using something to make the APR-38 low band antenna receivers. There are six on the nose, three per side, and one more on each side of the tail for a total of eight.
From the front each antenna has an inverted "T" profile. So I looked for some "T" shaped strip styrene there. No joy. But... :hmm: They had some "I" or "H" beam stuff and I found some that looked the right size. So I bought a pack and picked up the other supplies and home I went. My original intent was to cut each proper length, file off what was needed from the "H" to make a "T" and then final shape the antennas. But once I cut the first length an idea popped in my head- cut across the length diagonally and I could get two antennas per section.
so here is how the first pair came out
And in the meantime, I sanded the strip styrene shims smooth then added some Mr Surfacer to blend that work in better...
that is drying now and I will get that sanded smooth tomorrow.
Re: Revell 1/32 F-4G Review & Build- update 10/31
The Mr Surfacer dried more quickly than I thought it would... I sanded the stuff smooth a little while ago...
So my session today was more white work... As in white plastic improvisations. Building antennas. I could not find one clear photo of the forward lower APR-38 high band receiver antenna. But image searching turned up some other system high band receivers, so I based mine off those.
I started with some tube styrene with a base glued into place
then I began to add the low band APR-38 receivers to their positions around the nose
as well as the side chin scoop openings
then I sanded down the tube on the High Band Receiver for a more proper look
so now that is 18 antennas added to the nose on this kit... after all a Weasel needs to be able to sniff out its' prey...
and I made up two more Low Band Receivers that will go on the tail.
Re: Revell 1/32 F-4G Review & Build- update 11/01
That nose section is coming along really nicely Stik - All of that added detail is going to really make it stand out when it's painted up.
Thank you Stuart. I have almost completed what I set out to do on the nose area...
More white work today. Added wiring to the bottom instruments, then I added the two upper rows of instrument housings and the glare shroud to the top of the rear IP.
That's all for now...
Re: Revell 1/32 F-4G Review & Build- update 11/02
Ok, I now have this area properly wired up. It is about 70% accurate, and 30% inferred guess work...
all done back there except for paint...
Re: Revell 1/32 F-4G Review & Build- update 11/03
Great work Stik - I've always liked that effect, there's a lot of detail on the backs of most ip's that gets missed too often - even when visable.
Well worth the effort!
Return to “Product Previews & Reviews”
