1/48 F/A-18E Super Hornet
Re: 1/48 F/A-18E Super Hornet
You’re doing just fine Mike.
Nice. Impressed as to the minimal collateral damage around the areas you are working.
Thanks guys! The trick Lyle is that I lay some Tamiya tape around the area to help protect the other areas. I also use very narrow sanding sticks that I get from Hobby Lobby.
Good tip. I have those sanding sticks and have taped off areas...still looks like I hit it with a bench grinder.
I also use sanding pads after the main sanding to smooth things out.
Have a couple of those, too. I guess I don’t use a light enough touch.
Sand just enough to fix what you need to fix. Use putty too if you need to.
Here's a pic of the same area after using some putty for the gaps. I noticed that it needs some more work on the outside of each flare/chaff bucket.
Very well executed.
Well everything from the tails to the LERX (leading edge root extensions) are done on SH #1. The front of the LERX nearest the fuselage will probably need some more work. After that it's the front fuselage and nose. I'll get back to SH #2 when I'm done with #1.
