Looks great. What a treat to watch, learn and have a ringside seat! Watch your time!
You’ve got this!speedgraflex wrote:Great! Thanks Blacksheep! I have to finish before the 19th so the heat is on, buddy.
Thank you, Stuart! Thank you, Lyle! Thank you, Carlos! I’m going to work on the underwing crosses for a bit.
Play with your paint/thinner mixes. Ideally, you should be getting zero grain when shooting through an airbrush. I'll accept a certain amount as a flat coat will hide some grain. Using more thinner will reduce the grain. Don't be afraid of watery mixes as long as they don't run on application. Using an airbrush is all about building up layers.
Thank you so much, John! Your advice means the world to me!!
Yep , they're pretty small beasts in 1/72!
Looking good Bruce
Looking good Bruce
Yep haw! Now we’re cookin’!
Thank you, Stuart and Lyle. I added the profile since that is what I am color matching to a great extent, in the interests of critiquing my limitations which are many. I have been puzzling over how to create the proper white blue. Initially I thought I was close enough here.
However this should be much lighter.
Since the project is one quick series of “Crazy Make ‘Em Ups,” I am going to try a few tests with my paint on hand. That was why I pulled out the 1/32 Bf 109 G-Series wing. I am going to use that as my paint mule. With the clarity of hindsight, I chose one heckuva subject to build and paint in three weeks without the “correct” paints, but I do enjoy the challenge, and I am “over the hump” with any reservations against building or getting lost in finescale details. Let’s see how close I can get to that Late War Luftwaffe Weisblau.
Today-
Finish painting the fuselage insignia; Done
Paint the 1/32 Bf 109 Gustav wing to look as close to RLM 76 as possible; with the goal being once the fuse is closed up to adjust the lightened RLM 65 to RLM 76; Done
Mask the canopy or at least the fixed front section of the canopy; the windshield. I found a good pair of images online:
Happy Hump Day!
Today-
Happy Hump Day!
Man those end of war photos...
Those survivors went from being objects of fear to objects of curiosity.
This is coming my together nicely Bruce. You have got this well in hand.
