Medic's Lounge
-Latest Acquisitions
Re: Medic's Lounge
YES!!!!! I got both Iwata Neo's working!! One I use for priming and the other for clear coats. There will be a ton of painting coming up now.
Re: Medic's Lounge
Good for you!
Re: Medic's Lounge
Congrats! I also use my NEO for base coats and clears. My Sotar is used for detail work and weathering. Way to go getting them working!
Re: Medic's Lounge
Thanks guys! Yeah they're just for grunt work. I have an Iwata HP-C+ and a Badger Renegade Chrome for finer work.
Re: Medic's Lounge
Well done. I need a crash course in double action. I've just done a tiny bit of work and the brushes are so finicky compared to my Paasche H. Operator error no doubt.
Re: Medic's Lounge
keavdog wrote:Well done. I need a crash course in double action. I've just done a tiny bit of work and the brushes are so finicky compared to my Paasche H. Operator error no doubt.
It takes time to learn and I'm still no where near as good as most people.
Re: Medic's Lounge
Yes, double action brushes are a difficult thing to master. Some brushes have a tiny screw behind the trigger which can restrict how far you pull back the trigger. This helps if you need a lighter coat of paint over a broader area; as well as allowing for more controlled weathering. Still, practice helps tremendously.
Re: Medic's Lounge
I enjoy using them. Lots to learn there. I'm failing at maintaining them. I get a couple good sessions then they get all mucked up. I just need to watch a few videos.
Re: Medic's Lounge
Made a slight change to the paint side of the bench. Since I'm right handed, I needed things on that side so that they were closer. I moved the two organizers to the right side and got rid of one of the Vallejo paint racks since I didn't need it.
Re: Medic's Lounge
That's a niceeeee set up Mike!
