1/72 Hasegawa B5N2 Kate
Re: 1/72 Hasegawa B5N2 Kate
Ok I'm confused. What and how is the Worn Effect acrylic fluid used? Is it a paint that gives it a worn look? Or is it used for chipping effect?
- Modelcrazy
- Addicted Member
Black Sheep.BlackSheep214 wrote:Ok I'm confused. What and how is the Worn Effect acrylic fluid used? Is it a paint that gives it a worn look? Or is it used for chipping effect?![]()
It's used for chipping effect like hairspray.
Thanks Portman. I'll be working on chipping tonight.
- Modelcrazy
- Addicted Member
Here’s tonight’s work. I whetted a stiff brush and went over the areas that are chipped. I when ahead and added a slight amount of chipping to the wing Hinomarus. The only pictures that I can find of the plane were during the Ceylon in May 42. I’m figuring there was a little more chipping during that month before Midway.
Next I want to add some panel lines and some wash. I also need to finish the canopy and add the pitot tube.
That worked really well!
Seeing the result I was thinking the exact same thing!Medicman71 wrote:Yep. Need to get some of that.
Cool Great job on the paint.
- Modelcrazy
- Addicted Member
Thanks guys. I love the AK chipping fluid. They also have Heavy Worn Effects which I would like to try and would work well with a derelict subject such as an abandoned vehicle.
- Modelcrazy
- Addicted Member
Thanks John,
OK guys I’m done with the Kate. It depicts AI-301 from the Akagi with a 6 bomb load out. Not a bad little kit for an older mold. There was some flash that needed to be removed and I used the bombs and tail gun from the Airfix Kate. The base is the 1/72 Japanese Carrier base form Coastal kits.
Steve
Steve
