1/32 Trumpy P-51D Finished
Fermis
Re: 1/32 Trumpy P-51D
Post by Fermis »
Thanks again!
I got a bit ahead of myself, due to the limited time this past week...and just pressed on with this build. Completely forgot about doing a toot on the stripes. I'll do something soon, that will require stripes, and make sure I detail the process in the wip. It'll be a little easier to show, if I do it as it goes, rather than in retrospect.
Anyway...
Got this one wrapped up.
In addition to all the final pieces, after a dark wash, I sprayed over the OD and markings with clear flat, and added a little bit of very dark grey to the clear and sprayed the exhaust stains.
In addition to Trumpeters typical inaccuracies, another bugger about this kit...all the control surfaces are separate. That is nice, but they all need to be modified, in order for them to be attached in any way other than in neutral position. I don't see any single "issue" as a deal breaker, but when there's accuracy and engineering issues from start to finish...even down to the decals (there were some that said "P-47" on em...???!!!)...I would not recommend this kit be bought at retail price!!! 1/2 price on a vendor table...maybe!
Re: 1/32 Trumpy P-51D Finished
Nice build and you managed to whip it into shape despite the inaccuracies. Well done!
Despite all the issues, you still managed to finish a stupendous masterpiece! That shows the depth of your serious talent! I bow in the presence of greatness. :bow: :bow: :bow: :bow: :bow:
:shoutout: Bravo!
Another top notch build here! While the kit may have faults, your skills do not.
Fermis
Post by Fermis »
Thanks guys!
This project was enjoyable enough...especially since there's a check at the end!!!
CallSignOWL
Post by CallSignOWL »
Stunning! Absolutely stunning!! :wub:
