Tamiya F-15A
Re: Tamiya F-15A
Don’t worry about the ECM pod. Keep it and the pylon for your spares bin. F-15s never carried those operationally. I don’t know why the different model companies include those on their kits. The F-15 has a full internal suite of ECM devices. Those tubes on the tops of the tail fins are part of that suite.
Re: Tamiya F-15A
Re: Tamiya F-15A
Ah Really? Thanks for the tip Gents!
Re: Tamiya F-15A
Yes. The F-15 was designed with all the shortcomings of the F-4 over Vietnam in mind. A pure air to air fighter. The ECM pods in Vietnam took away a weapons pylon or missile bay. Build the system inside the airframe and able to be changed/upgraded, and that shortcoming is eliminated.
Re: Tamiya F-15A
Although the ECM system on the F-15 is REALLY outdated now. The Strike Eagle is getting the new system but it's still undecided on whether the F-15C will get it.
Re: Tamiya F-15A
That makes sense. The C Eagle was supposed to have been retired as our primary fighter over a decade ago, and replaced in active duty by the Raptor. The Strike Eagle has no projected replacement on the horizon, so it needs the most current ECM.
Re: Tamiya F-15A
I wold love to see the -C Eagle get it too. I know the Raptor was supposed to be our main fighter now, but the Eagle is still a magnificent and kick-ass aircraft!
Re: Tamiya F-15A
Well the Air Force needs more fighters and it needs a straight up fighter, not the F-35. Boeing is pushing a single seat version of the Saudi's F-15 Strike Eagles called the F-15X. Fly By Wire system, a cockpit display like the F-35, and turning on wing stations 1 and 9 for more missiles.
Re: Tamiya F-15A
Yes, I’ve read of the F-15 basically being used as a “missile truck for AMRAAMs linked in with either JSFs or Raptors to get closer and do the targeting work. Sort of an aerial version of how the Navy Aegis system can operate with the master battle being controlled from a single location via data links.
