Flanker Madness
Re: Flanker Madness
A fantastic body of work Fermis :shoutout: :shoutout: :shoutout:
Fermis
Re: Flanker Madness
Post by Fermis »
Stuart wrote:A fantastic body, Fermis :shoutout: :shoutout: :shoutout:
:tease:
:bag:
Fermis
Re: Flanker Madness
Post by Fermis »
Got the 2 little ones ready for paint...
Started with the J-15.
Dark grey "primer", which is also a color used in some areas. Those areas were masked, then I sprayed the light grey areas, masked, then the darker light grey areas, masked, then carried on with the usual pre-shading...
I mixed up yellow/camo grey/tan...for the overall yellow primer...
This is the particular airframe I'm doing...
There is quite a bit missed on the instructions....it is a Trumpeter kit, so what can you expect?!!! This kit is a Chinese knockoff of a Chinese knockoff!!!
After masking the tail, I mixed up willow green/camo grey/tan, for the tail...
Next, I'll get the other one caught up...then paint the NMF/exhausts at the same time.
Re: Flanker Madness
That's a superb bit of work Fermis, You've got the yellow primer spot on!
Re: Flanker Madness
so interessting, only primer not the camo.. :shoutout:
Re: Flanker Madness
Your airbrushing and colors used are excellent
Re: Flanker Madness
Wouh!
Re: Flanker Madness
There's spraying paint on plastic and then there is making a model come alive with color. Your work is always the latter.
Re: Flanker Madness
Oh Lord that’s tasty! The modulation you got in that color pushes it over the cliff for me. It’s beautiful. You took a color that by rights should be considered “boring” and laid it down classy and sexy and made it interesting. Lovely. I can’t wait to see what you do with the rest of the camo scheme.
Fermis
Re: Flanker Madness
Post by Fermis »
Thanks, dudes!
That was a very tough color to get...right?...acceptable?
Amazing how different it can look, depending on the lighting...even more-so with pics, which don't show it "true to the eye". (The subtle fading/weathering is blown out).
Been slow goin' (I have a remodel project going)
Got the 35 painted up.
Mixed RLM65, 76, and just a touch of "True Blue" for the overall. Light ghost grey. I saw refs that pointed to "true blue" for the camo. It looked WAY too blue and stupid. I mixed up something else and resprayed. It was better, but still looked stupid. Ended up using Intermediate Blue with a touch of true blue and sprayed yet again.
Going to keep this one on the fairly clean side.
Metal areas were done with MM metalizers, tinted with paint. Sprayed "exhaust" as a base, the rest (tinted colors) were done with dry brushing.
Gloss and decals next!
