Thanks! I hate getting stuck on models. I have to set it aside for a while and then come back to it.keavdog wrote:Great progress. I have a Hasegawa F-14 stuck right at this stage
MiG-29 Fulcrum Ukrainian AF
Re: MiG-29 Fulcrum Ukrainian AF
Adding PE brake lines to the gear legs.
Looking better and better with each update. What sort of scheme are you planning to use on this build? The kit markings or some combat markings?
Thanks Stik! I'm going to do the kit scheme of a Ukrainian Demo Jet. Almost all of it is paint and I have a friend that's working on getting some new Ukrainian markings since I don't trust the Academy decals.Stikpusher wrote:Looking better and better with each update. What sort of scheme are you planning to use on this build? The kit markings or some combat markings?
Look Good Mike - and what a great choice of scheme.
I've yet to start on mine, I've had my bench packed away for nearly two weeks!
Thanks! I just happened to have this boxing in the stash.
Added PE to the nose gear.
Working on the engines. I'm using the photoetch and hopefully I can get it to work. If not I'll order some resin replacements.
Those PE afterburners look good!
Thanks Stik! Here it is all built up. Now to work on the second one.
