Academy 1/35 scale M3 Stuart "Honey"
Re: Academy 1/35 scale M3 Stuart "Honey"
BlackSheep214 wrote: ↑Sat Feb 08, 2025 12:57 pm
What about the small top wheels and the rear idler wheels… do they have rubber on them? Or are they’re all steel wheels?
The small wheels are called return rollers, those have a rubber tire/rim. The idler wheel on this version is steel rimmed. A rubber rimmed idler wheel would be introduced later on during the war.
Thank you. :yipee:
I'm reading and following along and learning from you as you go! I like the way you create a "color palette" of parts using blue tape on cardboard! Do you do that for each project?
Always especially for fiddly parts. Easier to paint off the sprue than on them to reduce sanding any rough cuts. Been doing it this way for 20-30 plus years since I returned to the hobby.
More progress but pics forthcoming.
Individual track link parts painted Gunmetal and Humbrol track brown.
BlackSheep214 wrote: ↑Sun Feb 09, 2025 1:48 pm Always especially for fiddly parts. Easier to paint off the sprue than on them to reduce sanding any rough cuts. Been doing it this way for 20-30 plus years since I returned to the hobby.
Thanks, Tom! That makes a whole lot of sense.
One section of track link done...
Not glued on but to see what I got done...
Second Caunter scheme color is on! Silver Grey Green No.28.
Next color... Slate No.34
Very good start on the tracks Tom. Suggestion… paint the idler wheel contact surface shiny steel, as well as the outer edges that would contact the edge connector teeth.
Stikpusher wrote: ↑Tue Feb 11, 2025 8:17 pm Very good start on the tracks Tom. Suggestion… paint the idler wheel contact surface shiny steel, as well as the outer edges that would contact the edge connector teeth.
All of them and the rear large wheels? (Aside from the return wheels)
Fab progress on that camo and tracks Tom - keep at it!
