1/72 Hasegawa Shinmeiwa PS-1
Re: 1/72 Hasegawa Shinmeiwa PS-1
Monty, that is a super, neat-o solution to the engine length issue. Looks great!
If you are in for a radical conversion you could try to turn it info a US-1. That is the newest version with six bladed props.
http://en.m.wikipedia.org/wiki/ShinMaywa_US-2
VanceCrozier
Post by VanceCrozier »
Interesting to see this one being built. I had a chance to buy one several years ago but was pretty sure I had NOWHERE to display it at the time. :lol:
dmminiatures
Post by dmminiatures »
BorgR3mc0 wrote:If you are in for a radical conversion you could try to turn it info a US-1. That is the newest version with six bladed props.
hi Borg - yep, saw that US-2, and even a video of the aircraft taking off. really neat looking A/C. Looks like i am still a puppy :dogwag: on the conversion bit, and will stick to the old PS-1.
Monty
Monty / dmminiatures
dmminiatures
VanceCrozier wrote:Interesting to see this one being built. I had a chance to buy one several years ago but was pretty sure I had NOWHERE to display it at the time. :lol:
Hi Vance - Its been on my stash for a while too. still figuring out what to do. did a few cutting but was insignificant. I was cleaning out my pile of boxes a while a go when I saw the box and said well what the heck, lets do it!
Monty
dmminiatures
LyleW wrote:Monty, that is a super, neat-o solution to the engine length issue. Looks great!
Thanks Lyle. I made an extension on my C-130H with styrene and man, it was painful. probably i didnt know the tricks yet. then I went on working to extend the engine nacelles of a C-130J for a friend. this time using resin - that was messy. so i am glad this works out fine (for now!).
dmminiatures
putty time. using my trusty Tamiya epoxy putty. no problem so far, just needing to wait till the putty hardens and then sanding. i will have to let go of the nacelle's surface details from the sanding, sadly. :headbang: and will need to rescribe.
Meanwhile, sanding the upper fuselage. its a mess. what I usually do is that after the first phase of sanding, I coat the area with a thin layer of super glue...wait for 10 minutes and and sand smooth.
Tremendous work Monty! I am amazed at the excellent work you're doing to fix this. I have one of these in the stash and since I'm even more of a Puppy when it comes to scratchbuilding and fixing things; I'll be building mine out of the box. I do hope to start this in the beginning of the new year once I finish a couple other large aircraft I have in progress. Another Forums I'm a member of is doing a Group Build of floatplanes and I'll be starting this one for it first. Later, if I have time, I'll also do a Martin Mariner that I also have in then stash. Meanwhile, I'll keep watching this one.
lawdog114
Post by lawdog114 »
Looking good Monty...
Is this the UV Putty that hardens in daylight?
