Re: Revell '56 Ford F-100 -Fuel Line & Fenderwell Update 08/
Brilliant recovery on that fuel line Mustang! Way to go! This is continuing to be a pleasure to watch.
Re: Revell '56 Ford F-100 -Fuel Rail Problem...Solved! 08/20
mustang1989 wrote:Well I've got the fuel line installed and routed. I used a pin for chrome fuel line and coated it with some Tamiya Smoke X-19 to give it that true metal look and made a 90 degree banjo fitting to go onto the fuel rail at the carbs. Check it out....
I started on the inner fender wells yesterday by removing all that nasty molded on detail and cleaned it up and painted it.
Before:
And after. (This still needs to cure out so I can polish it up and make it into a mirror finish but you can see the difference so far)
Thanks Stuart, Mark, Jimmy and Carlos! I got a little progress done over the weekend but nothing worth pics. This morning I started on the carpet. It's tricky working with the flocking material to get it as even as possible. Pics soon.
Re: Revell '56 Ford F-100 -Interior Progress 8/25
I didn't much like the seating that came in the original boxing (and never really have to tell you the truth).....
So I upgraded from the 1/24 Monogram 55 F-100 kit seat which looks a helluva lot more up-to-date and a lot neater in appearance. (I'm glad I bought that kit in the beginning to supplement this build.)
After a lot of clean up on the seat platform I washed both parts this morning and they'll be in the primer stage by later this morning.
Re: Revell '56 Ford F-100 -Seat & Interior Accy Parts 08/28
I was going to get up yesterday morning and work on this beast some more but had a pretty bad headache so I slept yesterday's session out. I did have some time later on in the morning after about 5 more hours of sleep to siddown and work on the drivers seat some. Some dust had landed in the paint (go figure!) so I lightly sanded the affected areas with some 3600 to smooth it all out and went too far and would up down to the primer in two spots. No worries though. I got up this morning and shot another coat of paint on the seat and on the riser. I also primed the interior fuel tank yesterday and painted this it a gloss dark red this morning. One step forward...two steps back. More progress in this coming week. I re-worked and primed the cab and hope to start laying paint down on the it by Friday. I aint gonna waste time with pics much till then just because there aint enough progress on it to justify them yet. .
109
- Junior Member
That seat looks great. Did you carve it from styrene?
Bye!
Bye!
Thanks 109! No sir I robbed it from a spare kit.
