Yes, but it's a super thin liquid. Applied in little dots via tooth pick. I attack allot of my open canopies this way.Stikpusher wrote:Fogging on the canopy? Are you using CA glue to attach the canopy?
Airfix BP Defiant in 1/72
- CallSignOWL
- Addicted Member
Re: Airfix BP Defiant in 1/72
Got ya... anytime you use CA, it is a possibility.
I read somewhere (probably on that there entry-net, so it has to be true) and it seems to work.....coating the clear part in Future and then gluing with CA will eliminate or minimize the opportunity to fog up.
- CallSignOWL
- Addicted Member
Yes, that's what I learned too. Perhaps I forgot to dip it first, but I still used only a little bit of glue.... And the turret came out fine, so idk!LyleW wrote:I read somewhere (probably on that there entry-net, so it has to be true) and it seems to work.....coating the clear part in Future and then gluing with CA will eliminate or minimize the opportunity to fog up.
If some seeped inside, the fogging makes sense.
