1/72 Dragon P-61Finished
Fermis
Re: 1/72 Dragon P-61
Post by Fermis »
Thanks guys!
Gettin close!
BorgR3mc0 wrote:How do you do those engines? I have a Quickboost set for the Dakota. But the wiring and rods are putting me off. So do you paint first? Then add rods and wire and the detail painting? And you you drill the holes in the engine for the wire or are those dents enough?
I did paint the engine first...as it is. Then added the rods (trial-n-error, to size the first one, then used that as a guide for the rest)..painted those. I did drill for the wires. Each pair of wires is a single wire, folded, leaving a tiny CA holding loop....dip it and stick it! I did half of the top cylinders, let glue dry, trimmed and bent to shape...then did the other half (they get tricky to handle when you have wires sticking out all the way around). Repeat for the bottom row of cylinders. I completely ignored those tiny dents.
Thanks for your detailed anwser Fermis. This was just the stuff I needed to know!
Fermis
Post by Fermis »
BorgR3mc0 wrote:Thanks for your detailed anwser Fermis. This was just the stuff I needed to know!
You're welcome...glad to be of service!!!
Fermis
Post by Fermis »
Done!!!
Trying to light this thing, for the camera to pick it up like the eyeball, is about impossible.
This is about as close as I could get, to how I see it with me eyes...
Scruffy
Re: 1/72 Dragon P-61Finished
Post by Scruffy »
Awesome result Fermis! That is an older kit and not the easiest to put together. Great job.
Looks great. The color modulation on top is right on.
CallSignOWL
Post by CallSignOWL »
Well done, Fermis! I did a 1/48 scale Monogram version back in my youth years. Big bird and a fun build back then.
Top of the line work! :shoutout:
I just noticed there aren’t any gun barrels on the dome piece. I’m assuming only the nightfighter versions did?
