1/48 Tamiya Mosquito NFII, 307 Squadron RAF
Re: 1/48 Tamiya Mosquito NFII, 307 Squadron RAF
Clint I just saw this. You will love this kit. I built the NF.XIII a couple of years ago. Absolutely fantastic
Thank you John. I am really enjoying it so far. I just got my RB models gun barrels so will have a update tomorrow.
A few photos to share.
First the beautiful PE IP. I have added a drop of gloss to the dials after this photo. I wired up the radar thanks to the photo Bruce found. The Tamiya panel doesn't match 100% but you aren't going to see much of it anyway when it's all closed up.
Next I added the cockpit assembly into the right side of the fuselage added a bit more wiring and the HGW belts. The tops wasn't that bad but I ended up ruining the lower lap belts luckily I had the Eduard PE belts and was able to weather them so they look close to each other. Once the canopy is on I don't think you would be able to tell they are different.
The HGW set also came with a cloth map that I folded and added into the empty spot next to the navigator. The belts are a total headache to work with. For one they are two ply. Second the instructions tell you to cut the pieces then roll them into a ball, if you do that they separate from each other and I did it very carefully I didn't go after them like they owed me money. One part stays kinda usable but has no color. The part with the color printed on it is like trying to work with chewing gum it just isn't going to happen. If you bend them to much trying to get the buckles threaded they will also separate. You really only have one shot at getting the buckles looped into the right spot maybe two if you are lucky with out them coming a part on you. Maybe I got a bad set, I have a few more to try out on future builds.
Thanks for looking in!
SKOL!
Beautiful work!
Clint, you’re Mossie cockpit is looking great! It may have a couple imperfections, but once it’s under glass, it will be hard to notice. Only you will know.
Beautiful cockpit. love the panel.
Very nice! :shoutout: :shoutout: :shoutout: :shoutout:
Nice work! I need to get one of these. Following
Thank you everyone! It is a Tamiya kit and she's building nice and easy just like they always do.
Great work on the cockpit. Are you talking about the backing paper on the HGW belts? The backing is supposed to come off before you use the belts.
