Kitty Hawk 1/48 UH-1D Huey
April 1, 2021 through 12/31/2021 - Anything from the Vietnam Era, aircraft, helos, trucks, boats, tanks, artillery, figures, dioramas....if it walks, crawls, rolls, rattles, flies, hovers or goes "boom", it is in. Any scale.
Re: Kitty Hawk 1/48 UH-1D Huey
And off we go!
:popcorn:
Paul
Post by Paul »
I was enjoying building this kit, that is until I got to the rotor head where I boffed the entire assrmbly. :headbang:
YESS! Looking forward to seeing this one go together.
midnightprowler
Post by midnightprowler »
A little more painting done.
Will be using this with the PE in the kit.
1 Corinthians 15:51-54
1 Thessalonians 4:13-18
Ask me about Speedway Decals.
Just a couple of issues I ran into during my (yet unfinished) build.
The alignment bars on the inside of the gear housing shown in the instructions doesn't exist on the parts.
But the exact positioning of the base plate of the rotor head is super important. There's a slight angle involved that leads to a slightly tilted rotor head.
The instructions also suggest molded details on the upper cockpit panel. Ridiculous. But for placing the PE you'd have to grind it down anyways so no loss for you.
midnightprowler
Correct on all counts. Mine did however have the supports in the correct height for the transmission plate.
Okay then. So they seem to have revisited the parts. Not bad!
Gonna have to keep these key points in mind for mine when I get to it. Yes....the mast assy is tilted forward just a tad. Off to a good start here Lee!!
midnightprowler
midnightprowler
Return to “Vietnam Era Group Build 2021”
