Sweet...JG 50 was a Mosquito Hunter Gruppe that was headed up by Graf after he was yanked from the Eastern front after reaching the 200 kill mark...Grislawski was his wing-man he brought with him...
1/48 Eduard 109G and another G and an E
Re: 1/48 Eduard 109G
Sometimes...I really hate researching!!!Manny1943 wrote:I found some nice G-8 refs:
What I have found, is that there were G-8s field fitted with cameras, and G-8s that were dedicated/factory recce birds. I have yet to find any pics showing that "blister" pictured...on ANY 109, and nothing representing it for "white 14", on models or color profiles...but the two aft camera ports can be seen.
Also getting conflicting info on the camo colors (go figure!!!)...I know I like the two-tone brown, brown/olive combo.
It is true that all recon birds were not created equally...seems the diagram I posted was representative of a factory-built G-8. Many G-6s were field-converted and only carried the two cameras that were located aft (square cut-outs)...these generally kept the designation as G-6.Fermis wrote:Sometimes...I really hate researching!!!Manny1943 wrote:I found some nice G-8 refs:
Close up of G-8 large port:
Expanded view:
Seems the factory G-8s also had this camera in the leading edge of the wing but it was usually disconnected cause it sucked:
As far as colors go. Based on my extensive and expensive research the plane in question was sand-yellow over RLM76...this is based on first-hand reports of some ground personnel who serviced this aircraft...over the years there have been some plates depicting a third color but its not so. Also, if you look at he B&W pics there is no distinct contrast at all among the surface color, suggesting just one shade...
My conclusion is that the MOFO looked like this:
It seems obvious as to why there aren't many/any pics of these ports---they are under the plane! Found this though:
I knew he was bluffing! Trying to back outta that complex, compound-curved port, aren't ya???Fermis wrote:
Ha...you ever know me to take things the easy way?!!!
I have no problem making part...I just thought I would see that slight bulge on some of those side profile color plates.
No worries, I think you've posted enough ref material here, for me to get the job done....Thank you very much for that!
If you ever feel like you NEED a reason to drink....I'd recommend closing up the fuselage around an engine assembly that doesn't want to be there (talking about the "E")....and then...start working on a Brassin engine
I'm going to bed...
I'm going to bed...
- scorpiomikey
- Addicted Member
lol i know your pain.Fermis wrote:If you ever feel like you NEED a reason to drink....I'd recommend closing up the fuselage around an engine assembly that doesn't want to be there (talking about the "E")....and then...start working on a Brassin engine
I'm going to bed...
