The Children of Doom
Or, The Shelf of Doom. Since most of us intend to finish these someday....well, you know.
Re: The Children of Doom
Here is my latest bits of progress on this one…
First I airbrushed on white primer where the white ETO ID markings will be applied on the tail and cowling. The next day I airbrushed on Tamiya Gloss white to those areas
Yesterday in the morning I masked off the white ID markings will be areas, and also the wheel wells
Then in the afternoon I airbrushed on the Olive Drab 41 and Neutral Gray 43 using AK Real Colors
I need to go back and do some touch up on the OD and NG, then I can get the gloss coat on for decals… more to come in a few days…
Great progress! I went back through to see more detail about the actual aircraft and I’m excited to see the early insignia type in use! Thanks also for taking the time to include the battle damaged photos. Often this fine level of research into the life of the aircraft is totally missing from projects and I’m so happy to see you’ve included details about both the pilot and the aircraft, as well.
Progress! Can’t wait to see more! :shoutout: :shoutout: :shoutout: :shoutout:
Thanks guys!
speedgraflex wrote: Sat Aug 01, 2026 2:54 pm Great progress! I went back through to see more detail about the actual aircraft and I’m excited to see the early insignia type in use! Thanks also for taking the time to include the battle damaged photos. Often this fine level of research into the life of the aircraft is totally missing from projects and I’m so happy to see you’ve included details about both the pilot and the aircraft, as well.
This incident happened in June 1943, before the bars and red outline were added to the national insignia, so that is the reason for the style carried. I actually did a bit more reading on the aircraft itself and apparently it was repaired, issued to another Fighter Group, and would fly combat until being lost in summer 1944. I’m surprised that any C’s were still flying combat at that time, with D’s rolling off the assembly lines in great quantities by then. And as far as the pilot goes, well, I first read his autobiography, “Thunderbolt” when I was in grade school, and got hooked on this tale at that time. Some things stick with you over the years.
BlackSheep214 wrote: Sat Aug 01, 2026 4:52 pm Progress! Can’t wait to see more! :shoutout: :shoutout: :shoutout: :shoutout:
I need to do touch ups to both the OD amd Neutral Gray, so it will be after then that I can get some more progress photos up. Sundays are days I usually don’t spend any time at my bench, so it will be Monday evening at the soonest… :whistle:
I appreciate your thoroughness and it becomes even more clear now that you've explained a personal connection from childhood! Cheers!
speedgraflex wrote: Sat Aug 01, 2026 8:42 pm I appreciate your thoroughness and it becomes even more clear now that you've explained a personal connection from childhood! Cheers!
There were so many books of that sort I read in school. I read above my age level, but seriously, compared to what I saw was out there for my kids compared to when I was a kid for books, was a night and day difference. I think I was in 3rd Grade when I first read the tale of PT-109. But that was barely 10 years after JFK had been assassinated, and he was quite revered in his place in history. At least where I grew up.
Thanks for explaining, Carlos! My father’s abiding interest in the Civil War dominated a great portion of my early childhood. I managed to find a comparable interest in local history—in the French and Indian War and the American Revolution.
I had a series of books on the Presidents which is probably where I first read about PT-109.
I believe adding specifics when known to a project can not only aid in the construction but provide context for those of us who are following along with you.
Return to “Shelf of Someday”
