Kari's bench 2021 -->
Re: Kari's bench 2021 -->
Stuart wrote:That sucks Kari, Personally I'd go the AM route!
:that:
Catastrophy hit my Wildcat build, while removing the carrier film.
The removal process of the first five roundels went so extremely well, that I decided to, why not, video film this removal process with the last, the 6:th roundel.
BUT, then Murphys Law kicked-in
:headbang: :headbang: :headbang: :headbang: :headbang: :headbang:
Oh man... I'm not sure I will use those new fangled eduard decals. That's not the first fail I've seen with them.
Oh sh**.... that sucks.
Oh Helvetti!!!! Sorry to see that Kari!
I'm sure it's fixable though.
Man those decals suck - they're much to much of a risk to use.
Thank you guys!
And yes Stuart, the swearing word Helvetti fits very well in this situation! :-D
To be honest,
I lost all the mojo for this build, will hopefully continue when I find a new decal of the right size to replace this one.
And then other details, antenna cable etc, could be done as well.
I tried to replicate some wear on the paint/marking.. but, it ain't good, a new decal can save this build.
But for the time being this bird is now waiting for better days.
:sad:
Oh, man... she's looking so so good! Can you lift the damaged decal with tape or ? If you post the diameter of the decal we can collectively rummage through the spares. This one is too nice to let sit.
Well, you did a magnificent job on this up to this point. I'll patiently wait for your final finish. It'll be worth the wait. :shoutout:
Kari, several companies make the US stars that you need. I’m sure that one of them will cover your needs. At a minimum some F4F decal sheets come with the stars as well as the aircraft markings, so that might be an excuse to get another… :stirpot:
Thank you guys!
Stikpusher wrote:Kari, several companies make the US stars that you need. I’m sure that one of them will cover your needs. At a minimum some F4F decal sheets come with the stars as well as the aircraft markings, so that might be an excuse to get another… :stirpot:
Thanks and you are absolutely right, I took also a look at AM decalsets, and there are a number of sets that has the decal needed.
That seems to be the way forward!
Return to “Member's Gallery”
