Looking good! That would make an awesome dually, too....
is the plastic as soft as it looks?
Der Beetle Bus XL-Pressing Forward-01/05
Re: Der Beetle Bus XL- Rear Wheel Tub Progress-10/09
Thanks Lyle and I hadn't thought about that one. lol.
I think I've got the rear suspension about figured out to where I can put the wheel in just the right place. I turned to AMT's 67 Chevelle SS396 for that. I sectioned out the framework for the axle well and graphed it into place. I had to shave some off of the axle mounts themselves so I could position the tire /wheel up into the wheel well a little but I think I've got it about where I want it right now. Still gotta figure out the chassis frame work and fabricate rear springs but those shouldn't be too big of an issue. Getting the rear suspension/ differential combo was the hardest part I thought.
Re: Der Beetle Bus XL- Rear Suspension-10/14
This is going to look very cool once done!
Thanks portman. I really hope you're right.
Well .......I got the primer coat applied and so far it looks pretty good. I've still got some work to do as there are a couple of things that didn't show up under the wipe down prior to priming but it looks like it's all manageable, but hey, a guy can't do all this cutting and hacking and NOT have any body work left over to do you know.
There are a few bubbles in the primer and I couldn't for the life of me figure that out until.............I let my dog outside and found out that it was raining lightly. There aint that many thankfully and a little sanding outta get rid of the few that are there. Whew!! Got by with that one!
Re: Der Beetle Bus XL-Primer Coat-10/15
It looks Joe much more than "pretty good", it looks excellent!
Impossible to say that is has gone through a serious extension process!
Thanks Kari. I've still got a lot of little stuff to iron out but I think we'll be ok overall.
More sanding on the body this morning after yesterdays priming stage. Just didn't like how the R/H side turned out and I had to dump the front fender flares as they didn't coincide with the flareless rear wheel openings so I got rid of them. No pics today but made what I feel like was alot of progress in the way of body work. I'm feeling pretty good about it so far. Next weekends push will be on the roof to smooth that all out. Till then.............it's back to the Arado............
LOL. Is that for the Beetle Bus or the Arado?
