AMT Kit S921-200 built by speedgraflex
Re: AMT Kit S921-200
I have some sanding to do tonight. It’s in the “in between” stage at the moment.
It's looking good Bruce, filling, sanding, rinse, repeat it's one of them very time consuming things but if you don't do it you'll regret it when you hit it with that first coat of primer or paint.
Thanks, Clint!!! Of course I test fit the end cap and popped both seams. Serves me right for thinking any form of glue adhesive filler known to humanity would hold this beast for long.
:shutup:
I'm not familiar with this kit, is it not styrene? Maybe using something heavy duty like straight MEK or weldon. I've been using plast-i-weld closest thing to tenex7r I have found.
Great ideas. When I have cash I will get that.
Boy, can I identify with that! hope you get it taken care of!
Commission 2
I will be on this for a little while; I’ll be back shortly!
That is superb work!
LyleW wrote:That is superb work!
Thanks so much! I’m basing the finish off this in particular.
I will be back on the E shortly. I feel a two day break ought to help things. I need to ask you: was the three and four blades recip mystery ever solved? I joined the FB group.
Cool! This is some kind of a "break waggon", right?
