Short Sunderland MK.I Italeri 1/72
BsYamato
Re: Short Sunderland MK.I Italeri 1/72
Post by BsYamato »
Thomas_M wrote:Ah! The enormous Junkers Ju 290 from Revell! A beautiful kit! Sadly mine didn´t survive a move some years ago...
This aircraft has a larger span in 1/72 scale than a 1/48 scale Boeing B-17!!!
Lol before to get the kit, seeing 290 pictures I'm used to think '' why this aircraft have so small engines? '' .. After get the kit I see was not the engines that are smaller than normal :yikes:
Thanks for comments and finally the Canadian one is again come back :winkgrin:
About time to see our Canadian back! :bye:
BsYamato
Post by BsYamato »
The paint used for this plane probably was enough to paint about 10 or more WWII fighters :(
Third and probably last layer of 23 for bottom surfaces
Also first (second on top) layer of 147+77 humbrol and starting to outline camo contours
At the next :)
I would hate to brush paint such large surfaces BSYamato but you make it look so easy!
BsYamato
Post by BsYamato »
Thaks Borg :)
Here final layer of mixed grey
two layer of green
and tonight started to drybrus panel lines (as postshadow) on the green
that's all for now, at the next :)
VanceCrozier
Post by VanceCrozier »
SO
MUCH
PAINT!!!!
scorpiomikey
Post by scorpiomikey »
:that:
BsYamato
Post by BsYamato »
:lol: :lol:
Highlights on the green, corrected the the darker colors, also drybrushed postshading on the grey and the light bottom color. Also removed masks
a bad problem... the humbrol i used for finished pieces , as rudders, floats and few other pieces does not match the actual i used for the fuselage etc ..
I suspect that the problem are the different stocks of color i used :pod:
At the next!
No need to worry: could have happened on the real aircraft as well. For me this is a nice touch on your model.
I like the different colors. I wouldn't call that a bad problem; I'd consider it more of a complimentary mistake. It almost looks like they had to replace those parts of the aircraft. I think it's a great look and that you should keep it!
