Gooooood morning gentlemen! How are you? I hope you’re all doing very well :grin:
The ebb and flow of my mojo has been slowly moving back to the flow stage, which I am very happy about, and I’m feeling like it’s time to complete my 1:72 and 1:32 A6M2’s project.
The work that I’d done up to this point, most especially on the 1:32, was pretty mammoth. I hadn’t realized initially how much energy it zapped out of me. Especially when it comes to the paint job, gee wiz. And I don’t necessarily like that- do a big push over the course of several weeks, get a lot done, and end up happy with the work but also feeling burnt out. That doesn’t really work for me. So I’m changing my approach.
And I’m thinking of completing the 1:72 Zero first.
...And in order to do that I have to finish building and detailing the engine, and paint it of course.
A while back we were all talking about wiring radial engines, and I recall saying that I “wouldn’t bother with wiring up a 1:72 radial engine.” Well, I think I may have changed my mind. I went through the trouble of wiring the cockpit, which was a lot of fun and I fee that extra effort does add something to this project, so shoot, why not wire-up the engine?
Thing is, that baby is small! Have a look:
See how tiny that crank case cover is? While I was able to successfully drill out the holes on the cylinder heads, drilling holes in the ignition ring seems like a no-go to me, because I don’t have drill bits that small and there isn’t enough material there to put fourteen holes in. Attaching the wires to the back of that piece is an option I’d considered, but that cover fits pretty snug and flush to the cylinder heads’ subassembly and that might mess the fit up. So I’m puzzling over that at the moment :hmm: . It’s not a big deal though. I’ll figure something out.
Anyway, thanks for looking! More updates forthcoming!
Hey, Kenny! Good to see you. That is still a masterpiece of work. Can't wait to see the engine.
Good to see you back at the bench Kenny - hope you're all doing well.
Looking forward to seeing how you go about wiring that thing up!
All right!!!! Kenny’s back!!!
Good to see you back Kenny. Wiring something up that small is gonna be a big task.
Welcome back Kenny! So good to see your work here again! Wiring the 1/72 engine???? Are you crazy??? Yes, we are and I think you'll find a way to do it! Since the view into the engine is restricted to a frontal view, how about rigging the wires from the cylinder heads back to the crankcase cover? If you get the lengths right, once you secure the wires at the cylinder heads, you could simply push the wires into place somewhere behind the ignition ring and maybe secure with dabs of glue?
I can't tell what scale that Zero is... a sign of the quality of the model molding and the skill of the modeler.
Thank you gentlemen very much! I appreciate the welcome back to the hangar.
Our friend Mr. John Kim just echoed some thoughts I’ve had this afternoon. There is a very slight lip formed by the ignition ring, which could serve very well for affixing the wires to *after* installing them into the holes in the cylinder heads. And that’s probably the most viable solution. Another thing I’ve been thinking about- how to paint those wires. Normally I attach them to the ring, then paint, then wire-up, then touch up. This would be different ... paint the cylinder heads and crank case cover, glue them together, then add the wires and touch-up. The material I’m planning to use though is a bugger to paint. It doesn’t hold paint very well. So there’s that. But thankfully it’s also small. So any issues with the paint chipping wouldn’t be hugely visible. We’ll see.
I would glue the wires straight into the cylinder heads and paint them when they are sticking up straight. And then I would push them into place and then make any necessary touch-ups afterward. What kind of wire are you using? I use lead wire for mine. They come in spools for flyfisherman to add weight to their flies.
I was planning on using the innards of a coaxial cable but your material sounds like a way better option. Coaxial wire can be unruly.
