1/48 Academy F-4J Phantom
Re: 1/48 Academy F-4J Phantom
Good to see you plugging away on this one! Sometimes it's hard to maintain momentum after a set back... I know I have that problem!
Yeah it really is. It needs to be reprimed in those areas and then paint but I'm afraid of building up to much paint. Any suggestions?
- Handiabled
- Master Member
Great to see this build back!!
Thin primer and paints more than usually and build them up in thin layers. So they blend in with the paint beneath and you can avoid it looking like corrosion control. Also spray with low pressure and from a short distance.Medicman71 wrote:Yeah it really is. It needs to be reprimed in those areas and then paint but I'm afraid of building up to much paint. Any suggestions?
I'll echo what John said about it's good seeing you back on this one.
Sometimes that happens on long drawn out builds. Hang in there with it Mike.
I think I know someone else that has an F4 languishing in the stash...huh, Carlos?mustang1989 wrote:I'll echo what John said about it's good seeing you back on this one.Sometimes that happens on long drawn out builds. Hang in there with it Mike.
Yeah, any built? Atsa lotsa phantom stuff
