John would have to answer that. The yellow Frog tape doesn't have the flexibility that the electrical tape would.BlackSheep214 wrote:Wouldn’t electrical tape be tackier than yellow Frog tape? I’m usually wary of trying that tape.
Fiat Br 20 e/m Cicogna 1/72
Re: Fiat Br 20 e/m Cicogna 1/72
The flexible White Tamiya Tape is what I use when I need to negotiate non-flat surfaces or curved patterns. Black electrician tape is what I used to use before I knew about the Tamiya stuff. When I first used the Tamiya Tape, I thought, "this is just electrician tape in WHITE." I find that both the Tamiya white tape and the black electrician tape offers slightly less adhesion to plastic than Tamiya's yellow tape. I don't think using electrician tape would pose a problem as a masking material if your paint is fully dry.
Undersidehttps://i.postimg.cc/05VVBSrY/DSC-0004.jpg sprayed and all the hinomarus painted.
And, a lot of work to do repainting the tail. Can't abide by the hand painted effort. Have to figure out how to get a mask piece under the braces....
I would make two “half circle masks” and cover the red which needs to be redone, then add back your grey undercoat. I might be slightly tempted to mask the circles and use a little wet sand paper at the 800-1000 grit level to reduce the opacity of the red overspray too, but that is a gentle touch and go process and depends on your paint adhesion and your patience.
This is pretty much in the dead file. Stepped on the windscreen while looking for it. I don’t know if Italeri can supply another.
Rest In Peace or Pieces... hopefully Italeri will provide!
Looks good enough for me. Well done!
Found three of four.speedgraflex wrote:Rest In Peace or Pieces... hopefully Italeri will provide!
Is there a vacuform replacement canopy available for this kit?LyleW wrote:This is pretty much in the dead file. Stepped on the windscreen while looking for it. I don’t know if Italeri can supply another.
