Heinkel He 100: Intercontinental Friendship Model Shop Pt.1
Re: Heinkel He 100: Intercontinental Friendship Model Shop P
Just caught up from a few days ago. This is looking great.
Bolleken
Post by Bolleken »
Now I tried to shape the filled cowling section. The first loop wasn't sufficient. You can clearly see that my angle was wrong.
So I reworked that and I think after smoothing it looks now much closer to the drawing.
Also with the attached prop the shape looks now much bette (IMO)
Yes, it sure does look like you have captured the correct shapes there now. :hmm:
Bruce, thank you for the very kind words. I'm glad I was able to help in some small way. Take your time and we'll keep following this.
Marius, good eye catching that discrepancy. Looks like a perfect fix to me.
That's a fantastic bit of reshaping!
Wow! Some really great modifications there! It's always scary cutting up a kit for stuff like this. Y'all are doing a great job! :shoutout:
Note: this is the Lindberg ‘65 tooling, which is a dark gloss green plastic, I am building in the USA. Two kits, two modelers, a virtual side by side buddy build. (Orange line: propellor shaft, blue lines: figuring out the angles.)
You can see the area that needs to be built up with putty which is visible as negative space on the second image. I have adjusted the cowling angle to make it flatter and conform to the top of the engine itself; now I have to add the additional material after the backfill cures.
Excellent conversion work Bruce!
Looks fantastic Bruce! You are nailing this perfectly!
:P1:
Yes, you are doing some excellent corrective surgery on this model Bruce!
