Junkers F13 Floatplane by MiniArt 1:48
Re: Junkers F13 Floatplane by MiniArt 1:48
Raised padding done, window masks removed...
Next and final (!) steps:
1) The exhaust stack, already painted, just needs to be attached.
2) 'The propeller, should be more of a darker wood sort
3) The radio mast + antenna cable
4) Cockpit glasses
And then the Junkers is more of less ready. Have not decided yet, if I should do any weathering, even light touch-ups..
Let's see what next!
Looking good!
Thanks Tom,
last details and then I would say, it's done!
I am rather pleased with the propeller. I base-coated the propeller with Tamiya XF-60 Dark Yellow, applied Burnt Umber oil color over top, and then dragged a stiff paintbrush across it to imitate the wood grain.
All the other parts have been attached; antenna, cable, exhaust stack and the cockpit glasses..
Finally I have managed to finish a build, I think I will have a beer tonight!
:yahoo: :yahoo: :yahoo:
The end result soon to be seen in the "Completed builds" section
FullMetal
Post by FullMetal »
OMG THAT PROPELLER IS FANTASTIC...and the built too..sorry I missed it :headslap: :grin:
Right on! That prop is just money. There's some things you can only do with oils.
That's beautiful work, Kari! :bow:
KSaarni wrote: Sat Aug 22, 2026 10:54 am Thanks Tom,
Day-um… that propeller looks very real. Is burnt umber artist oil acrylic? What type of stiff rush did you use? When you say over the top, do you put a dab on the tip for both sides?
I never could make anything to look like real wood on a model kit accessory. :bag:
