I have been at this point on a number of occasions, prior to cockpit install and wondering how I am going to bridge that gap. I suspect (and certainly cross my fingers for you) that the problem will be self solving once the insert has been, well, inserted!
Regards,
Revell Spitfire Mk IX 1/32
kahunaminor
- Advanced Member
Re: Revell Spitfire Mk IX 1/32
Kent in Oz
Thanks Kent, I really hope so too!kahunaminor wrote:I have been at this point on a number of occasions, prior to cockpit install and wondering how I am going to bridge that gap. I suspect (and certainly cross my fingers for you) that the problem will be self solving once the insert has been, well, inserted!
Regards,
There's different ways to approach the wing root gap. (1) you can bend the wings upwards, (2) you can spread the fuselage, or (3) you can bridge the gap using shims. I would wait until the cockpit assembly is in place... it could very well spread the fuselage enough to reduce/eliminate that gap.
speedgraflex wrote:https://www.largescaleplanes.com/articl ... p?aid=3219
“The molding is slightly short...”
Pictures updated a la cc
Thank you! Would you check pic 1 on page 1, please?KSaarni wrote:Pictures updated a la cc
Checked and Corrected!
Thanks Bruce, almost... no, actually not almost but it is embarassing to miss to correct the very first picture !
No worries, Kari. Not embarrassing at all. Usually the first posting is either photo- or text- heavy, so that makes editing trickier.
