Medic's Texas Viper
Re: Medic's Texas Viper
Thanks guys! Lots of progress last few days. Working in the front intake right now.
Mike, I finally got caught up. What magnificent work you've achieved so far! Awesome man!
Thanks Duke!
Medicman71 wrote:Under the category of "things that make you go crosseyed", the PE battery for the Viper.
Marvellous details !!
:wow:
:headbang: :headbang: :headbang: So I may have screwed this one up already. If you've ever built (or will build) a Tamiya Viper, don't go by the instructions when it comes to the intake. The main gear bay makes up the back half of the intake. DO NOT assemble and install it the way it says in the instructions. The way to do it without issues later is this.
1. Glue together the two bottom intake parts and then the two upper intakes parts. This gives you the ability to remove the seam that would be seen halfway down the intake.
2. Glue the upper and lower intake halves and the other front intake parts together.
3. Snake the whole assembly into the bottom fuselage half and glue once in position (do this BEFORE gluing the fuselage halves together).
Well guess who forgot this whole trick. YEP!! And this is what happens. That massive gap is NOT supposed to be there between the intake and lower fuselage.
Ouch! Keep after it!
Medicman71 wrote::headbang: :headbang: :headbang: So I may have screwed this one up already. If you've ever built (or will build) a Tamiya Viper, don't go by the instructions when it comes to the intake. The main gear bay makes up the back half of the intake. DO NOT assemble and install it the way it says in the instructions. The way to do it without issues later is this.
:writing: :writing: :writing:
Good to know since I have a couple Tamiya Vipers in my stash.
When you build them, let me know and I'll help you with it in case my instructions weren't clear enough. I tried to explain it best I could.
I will NOT be defeated by some damn intakes!!!! :ggun:
Return to “Jet GB by Portman”
